BIMMULTISELECT command
Selects linear solids.
Icon:
Selects linear solids with coplanar and/or parallel axes.
Method
Selects linear solids with coplanar and/or parallel axes. If a face of a linear solid is selected, the corresponding faces of the linear solids with coplanar/parallel axes are selected.
Note: Select a different face by repeatedly pressing the TAB
key to cycle through all faces of the selected solid.
Options
- all Coplanar axes
- Selects all solids of which the axis is coplanar with the axis of the selected solid.
- coplAnar and parallel axes
- Selects all solids of which the axis is coplanar and parallel with the axis of the selected solid.
- all Parallel axes
- Selects all solids of which the axis is parallel with the axis of the selected solid.
Note: Press the Ctrl key to cycle through the command’s
options. Hot Key Assistant must be set ON.
