BIMMULTISELECT command
Selects linear solids.
Icon:
描述(D)
Selects linear solids with coplanar and/or parallel axes.
方式
Selects linear solids with coplanar and/or parallel axes. If a face of a linear solid is selected, the corresponding faces of the linear solids with coplanar/parallel axes are selected.
选项(O)
- all Coplanar axes
- Selects all solids of which the axis is coplanar with the axis of the selected solid.
- coplAnar and parallel axes
- Selects all solids of which the axis is coplanar and parallel with the axis of the selected solid.
- all Parallel axes
- Selects all solids of which the axis is parallel with the axis of the selected solid.
Note: Press Ctrl key to cycle between command’s options. Hot Key Assistant must be set ON.
