BIMPROPAGATE command
Maps details related to selected base solids to similar base solids in the model.
Icon:
描述(D)
Maps details (solids, holes, finishing geometry, etc.) related to selected base solids to similar base solids in the model and optionally outlines the detail in a grid.
方式
Select reference solids and, optionally, detail entities (solids, block references, faces, edges, etc.).
It can be used to copy details throughout your model.
Note: The detail area to be copied is displayed in blue. The reference contact area is displayed in purple.
You can accept or reject suggestions by clicking on the tick.
- A green check mark means that the suggestion will be applied.
- A question mark means that the suggestion will not be applied due to one of several possible reasons.
- A red X mark means that the suggestion will not be applied.
Note: Hovering over the widget will reveal more options.
Options within the command
- 块
- Propagates the detail as a block.
- 复制
- Propagates the detail as a copy.
- 先膨胀
- Expands the sensitive zone to include similar solids which are not connected yet in the model. The edges of the initially detected detail are moved outward over a specified distance.
- 保存细节
- Displays the Save Drawing As dialog box, which allows you to save the detail.
- save detail to Library
- Displays the Save Detail dialog box, which allows you to save the detail to library.
