BIMQUICKDRAW command
Creates and edits spaces and buildings.
Icon:
Quickly creates and edits rectangular and L-shaped spaces and buildings. The layout of the QuickDraw cursor represents the space being created. It also indicates the alignment with existing walls and distances from existing solids.
Note: If dynamic input (DYN) is set ON, the dimensions are
displayed, as the spaces are created. The dimensions can also be entered
manually.
Note: The default settings can be changed in the Settings
dialog box.
Options
- Floor to Floor Distance (Floor Height)
- Sets the floor to floor distance. The value is saved to the FLOORTOFLOORDISTANCE system variable and will be used until set differently.
- Wall Width
- Sets the width of the walls being created. The width is saved to the
WALLWIDTH system variable and will be used until set differently.Note: The default value is 250mm.
- Slab thickness
- Sets the slab thickness of the room. The thickness is saved to the
SLABTHICKNESS system variable and will be used until set differently.Note: The default value is 250mm.
- Auto adapt sizes
- Allows to copy the wall width and height from an existing wall, thus
overriding the current value of the WALLWIDTH system variable.
- ON: The width and height are copied from the highlighted wall when you place the QuickDraw cursor against a wall to specify the first corner of a new room. When two walls of different height or width highlight (corner), the dimensions of the wall that highlights first are copied.
- OFF: The values of the FLOORTOFLOORDISTANCE and WALLWIDTH system variables are used.
- Add story
- Adds a story to the existing building:
- Full copy of the top floor.
- Copies the slab and the outer walls of the top floor.
- Finish the building with flat roof.
