BIMQUICKWALL command
Creates X- and Y- axis aligned walls.
Icon:
Allows you to easily create X-axis or Y-axis aligned walls.
Note: The command only works if there is already a wall in the drawing. A red cross next to the cursor is displayed if the command is launched in a drawing without walls or when you click in the wrong place in a drawing to indicate the command cannot be used.
Methods
There are five methods to draw a wall using the BIMQUICKWALL command:
  1. Between two parallel walls (both ends of the newly created wall are connected to the perpendicular walls).
    Note: If dynamic input (DYN) is set to On, the distances to the parallel walls are displayed. Tap TAB key to switch between the dimensions and set them manually.
  2. As an extension of an existing wall, where both ends of the newly created wall are connected to walls (one to the existing wall being extended and the other to the perpendicular wall).
  3. As an extension of an existing wall, where only one end of the newly created wall is connected to the existing wall being extended (the other wall end is free).
  4. As a free wall with a configurable fixed length (the ends of the newly created wall are not connected to other walls).
  5. While in Top View Mode (TVM), by automatically detecting wall width from an underlying point cloud and setting it as the wall width value in the command context panel. The wall preview cursor adopts this width as well and sticks to the wall location.
    Note: To enter the TVM, open the Story Bar by setting the STORYBAR system variable to 1 or 2, then click a story disk to activate a story.
The Quick Wall command context panel opens when the BIMQUICKWALL command is launched, as well as the Hotkey Assistant widget.
  1. Dimensions
  2. Placement
  3. Composition
  4. Spatial location
  5. Magnetic Snapping
Dimensions
Allows you to define the walls dimensions.
Wall thickness
Sets the thickness of the walls being created.
Wall height
Sets the height of the walls being created.
Auto-fill
Automatically fills in the Wall height field by searching for solids above the wall to connect to.
Free wall length
Sets the length of the free walls being created.
Placement
Allows you to define the walls placement.
Justification
Allows you to select the wall justification.
Wall top offset
Sets the top offset from the slab detected above the walls being created.
Note: This option becomes unavailable when the Auto-fill option is set to Off.
Wall base offset
Sets the base offset from the slab detected bellow the walls being created.
Composition
Click the browse button () to open the Compositions dialog box that lets you select a wall composition.
Spatial Location
You can accept the automatically assigned spatial location or define a new one by selecting an option from the drop-down menu.
Automatic
Assigns the detected building and floor to the walls being created.
Note: Selecting a different spatial location than the one automatically assigned toggles the Automatic option to Off.
Magnetic Snapping
Auto detect wall thickness
Controls whether the wall cursor should snap to existing walls thickness.
The Hotkey Assistant widget lets you change the direction of the walls to be created. You can press Ctrl key to switch between X-aligned wall and Y-aligned wall options.
Note: The Hotkey Assistant widget is displayed if the HOTKEYASSISTANT system variable is set to 1 and the Display Hotkey Hints for BIMQUICKWALL options checkbox is ticked in the Hotkey Assistant Configuration dialog box.
Options within the command
X-aligned wall
Creates an X-aligned wall.
Y-aligned wall
Creates a Y-aligned wall.
