BIMREASSOCIATE command
Automatically re-associates invalid Tags and Dimensions to the underlying geometry.
Select a BIM section viewport in order to automatically re-assign invalid Tags and Dimensions to the underlying geometry.
Note: The BIM "Associativity" property indicates whether a tag is associated.
Note: The BIM "Associative coloring" property visualizes an unassociated tag in red, if true. It doesn't change the color property.
