BIMROOM command
The BIMROOM command is obsolete and has been replaced by the BIMSPACE command.
BricsCAD BIM
Icon:
Note: You can still open BIM rooms, but it is not possible to create new BIM rooms or update their geometry.
Note: Use the Space option of the BIMCLASSIFY command to convert a BIM room to a BIM space.
