BIMSECTIONUPDATE command
Updates the result of a BIM section entity.
Icon:
描述(D)
Generates or updates the result of a BIM section in a drawing.
Note: The GENERATEASSOCATTRS system variables controls the generation of associative data on 3D solids during modeling. When set ON, 3D solids contain associative data from the moment of creation. This allows BIMSECTIONUPDATE to produce drawings for which dimensions and tags can be automatically updated when the 3D model has been modified.
方式
There are two methods to use the BIMSECTIONUPDATE command:
- Generate the result of a BIM section entity.
Note: If the Interior option of the BIMSECTION command was used during the creation of the BIM section, also BIM spaces can be selected.
- Update the result of a BIM section.
Note: Select a BIM section entity in Model Space or a viewport in Paper Space layout.
