BIMSTRETCH command
Stretches the ends of linear solids.
BricsCAD Shape; BricsCAD BIM
Stretches the ends of linear solids while maintaining previously made connections between other linear solids in the overall structure.
Method
There are two methods to use BIMSTRETCH command:
  • Stretch structural connections.
Note: Stretching elements that are classified as Beam, Column or Member.
  • Stretch MEP connections.
Note: Stretching elements that are classified as Flow segments.
Before using the BIMSTRETCH command make sure that:
  • ‘Display sides and ends’ is enabled.
  • ‘Display Axes’ is enabled.
  • Structural profiles are connected with StructuralConnect.
  • MEP connections are connected with FlowConnect.
Note: Before running the command, select the ends of the entities that will be modified.
Options within the command
Base Point
Specifies new basepoint to start the displacement from.
Copy
Makes a copy of the connected entities and places them in the new position.
Undo
Undoes the last action.
Exit
Exits the command.
