BIMTAG command
Creates associative tags.
Icon:
描述(D)
Creates associative tags in generated BIM section drawings for the corresponding building entities in a 3D BIM model.
Note: This command can only be used on section viewports.
Note: The GENERATEASSOCVIEWS system variable must be ON when generating or updating BIM tags.
方式
The tags are created automatically for all building elements in the selected viewport.
Note: Tags are created as multileader entities using multileader styles in _SectionTag.dwg. The content of such multileader style is a block with attributes. Each attribute refers to a property of a BIM entity type. BIM entity types are linked to a multileader style in _TagTypeToStyle.xml. All source files can be found in the Support folder, for example: C:\Users\<UserName>\AppData\Roaming\Bricsys\BricsCAD\V18x64\en_US\Support\Bim\Sections.
Options within the command
自动
Creates tags automatically for all sectioned building entities in the selected viewport.
手动(M)
Creates tags on background entities in sections and elevations.
目前多重引线样式
Allows to use the current multileader style instead of the default style for selected sectioned BIM elements.
更改标签类型
Changes the type of the selected tags.
组成
Tag with all materials of composition of the sectioned BIM element.
承重方向
Inserts a loadbearing direction symbol when a generated line of a slab solid is selected. Make sure the load bearing direction is set by the BIMSETLOADBEARINGDIRECTION command.
点标高
Inserts a tag that indicates the elevation of the identified point in elevations and vertical sections.
Note: The following options are available only if tags have already been assigned to the section.
更新现有
Updates the existing tags in the selected viewport. The position of relocated tag blocks is preserved.
update existing and add New
Updates the existing tags in the selected viewport and adds new tags.
全部重生
Updates all tags in the selected viewport. Repositioned tag blocks are moved to their default location.
