BIMUPDATESPACE command
Recalculates a BIM space which is out-of-date.
Icon:
描述(D)
Recalculates a BIM space which is out-of-date, for example, after adding or removing bounding entities. After the command is run, select all spaces to update.
Note: Only spaces that have the Update Method property set to Automatic can be processed.
