BIMWALL command
Draws a polyline shaped wall, unconstrained by the X or Y axis.
BricsCAD BIM
Method
The command creates walls unconstrained by the X or Y axis. You can define the options through the command context panel that opens when the command is launched, as well as through the Command line.
  1. Dimensions
  2. Placement
  3. Composition
  4. Spatial location
Dimensions
Allows you to define the walls dimensions.
Wall thickness
Sets the thickness of the walls being created.
Wall height
Sets the height of the walls being created.
Auto-fill
Automatically fills in the Wall height field by searching for solids above the wall to connect to.
Placement
Allows you to define the walls placement.
Justification
Allows you to select the wall justification.
Wall top offset
Sets the top offset from the slab detected above the walls being created.
Note: This option becomes unavailable when the Auto-fill option is set to Off.
Wall base offset
Sets the base offset from the slab detected bellow the walls being created.
Composition
Click the browse button () to open the Compositions dialog box that lets you select a wall composition.
Spatial Location
You can accept the automatically assigned spatial location or define a new one by selecting an option from the drop-down menu.
Automatic
Assigns the detected building and floor to the walls being created.
Note: Selecting a different spatial location than the one automatically assigned toggles the Automatic option to Off.
