BIMWINDOWCREATE command
Creates a fully parametric window or opening based on a closed contour.
Icon:
Creates parametric windows using as profile any entity such as a boundary, a closed polyline or grid.
Note: A series of parameters is created, which can be edited
in the Parameters section of the Properties panel.
Options within the command
- Window
- Creates a BIM Window entity. An opening in the solid on which the profile entity lies is created automatically. The Choose Window Style dialog box opens and the windows style can be chosen.
- Opening
- Creates an opening in the solid on which the profile entity lies. The opening is created by a solid on the BIM_SUBTRACT layer. This layer is frozen by default. Thaw the layer to select the opening.
