BIMWINDOWUPDATE command
Updates the opening made by a window or door in a solid.
BricsCAD Shape; BricsCAD BIM
Icon:
Updates the opening created by a window or door in case the definition changed in such way that the opening was not correctly updated automatically.
Options within the command
MOde
Allows to select the placement face, whether Automatic or Manual.
