BLIPMODE command
Toggles the BLIPMODE system variable.
Alias: BM
Toggles the BLIPMODE system variable to show or hide marker blips that indicate where you picked in the drawing. You can launch this command at the Command prompt or within another command by preceding it with an apostrophe: 'BLIPMODE.
  • On: turns on the BLIPMODE system variable
  • Off: turns off the BLIPMODE system variable
  • Toggle: changes the BLIPMODE system variable to the opposite of the current setting
