BLOCKIFY command
Converts identical set of entities (2D or 3D) to block references.
Icon:
描述(D)
Searches the drawing for an identical set of entities (2D or 3D) and replaces them by block references.
方式
There are three methods to use BLOCKIFY command:
- Converts 2D and 3D entities to blocks.
- Converts equally shaped solids to blocks.
- Optionally replaces block patterns by arrays.
Options within the command
- 搜索相等的实体
- Searches the drawing (or the selection) for equally shaped solids and replaces them by newly created block definitions. In case a solid match an existing block definition, the replacing block reference points to that block definition.
- 匹配现有块
- Searches the drawing (or the selection) for 2D geometry matching existing block definitions.
- 设置(S)
- Opens the Settings dialog box at the blockify settings.
