BMBOM command
Inserts a Bill of Materials (BOM) table in the current drawing.
Icon:
Options within the command
- Name
- Specifies the table name.
Note: The BOMTEMPLATE system variable defines the path to the
file with default BOM template which will be used to create new BOM
tables.
Note: If the BOMTEMPLATE system variable is empty or the path
is not valid, the below default BOM configuration will be used.
- Top level
- Creates a BOM of the top-level components only.
- Bottom level
- Creates a BOM of the subcomponents.
- Hierarchical
- Creates a hierarchical BOM listing all (sub)components.
- Load from template
- Opens the Select file with the BOM table template which allows you to select a .bom file to create a BOM from a template.
- Save as template
- Opens the Select file to save BOM table template which allows you to save the current BOM configuration as a template.
- LAyout
- Changes layout where the table will be placed.
- Configure
- Allows to add additional columns to your BOM table.
- Description
- Adds a description column.
- dEnsity
- Adds a density column.
- Volume
- Adds a volume column.
- Mass
- Adds a mass column.
- parameterS
- If multiple inserts of the same parametric component exist in the assembly, they will be grouped in different BOM rows depending on the values of the parameters.
- mAterials
- Adds a material column.
- Thickness
- Adds a thickness column.
- More
- Displays more configuration options.
- Toggle column
- Adds or removes columns from the BOM.
- add Formula field
- Adds a formula field.
- add Thumbnails
- Adds a thumbnail column
- Name
- Sets the name of the column.
- Width
- Sets the thumbnails width in pixels
- Height
- Sets the thumbnails height in pixels
- View type
- Sets the orientation of the camera.
- Orthographic
- Allows to choose an orthographic projection view.
- Isometric
- Allows to choose an isometric projection view
- viSual style
- Sets the visual style for thumbnails.
- BacKGround color
- Sets the thumbnails background color.
- Transparent
- Sets transparent background for thumbnails.
- seleCt color
- Opens the Select color dialog box to select a color.
- Folder
- Opens the Select image folder which allows you to choose a folder for thumbnail images.
- Add column
- Adds a thumbnail column with specified parameters to the BOM table.
- Set sorting
- Sets the sorting mode for the BOM.
- Automatic
- Sets the automatic sorting for the table.
- No sorting
- Disables the sorting for the BOM.
- Custom sorting
- Specifies the column for sorting.
- Toggle sorting column
- Sets the sorting mode for columns.
- column Properties
- Configures columns.
- Visibility
- Sets the visibility of the column.
- ON
- Makes the column visible.
- OFF
- Makes the column invisible.
- Width
- Sets the column width.
- Auto
- Sets the automatic width of the column.
- Prefix
- Sets the prefix for numbers in the Number column.
- Suffix
- Sets the suffix for numbers in the Number column.
- Delimiter
- Sets the delimiter between levels in numbers for hierarchical BOM tables.
- Numeration type
- Sets the numeration type for hierarchical BOM tables.
- Full numbers
- Numbers for each level are combined using the provided delimiter and shown in the Number column.
- Short numbers
- Only numbers for the current level of each part are used. This mode is supposed to be used with Level column.
- Continuous numbers
- All parts are numbered continuously, regardless of their level.
- Footer type
- Sets the footer type.
- None
- Removes the column from the footer.
- Sum
- Adds the total sum to the footer.
- Average
- Adds the average value to the footer.
- MINimum
- Adds the minimal value to the footer.
- MAXimum
- Adds the maximal value to the footer.
Note: It is possible to add footers to formula or template columns
as well.
Note: A different unit and format for footer values can be
set.
- Aggregate function
- Sets the aggregate function.
- None
- Removes an aggregate function from the column.
- Sum
- Shows the total sum of values in the group.
- Average
- Shows the average value of values in the group.
- MINimum
- Shows the lowest value in the group.
- MAXimum
- Shows the highest value in the group.
- CONcatenate
- Combines all values in the group using the provided delimiter.
- CONCatenate with count
- Combines all values in the group with their number using the provided delimiters, prefix and suffix.
- sEttings
- Configures the aggregated column.
- value Separator
- Sets the delimiter between concatenated values.
- count Position
- Sets the position of the number of encounters for concatenated values.
- After value
- The number of instances is placed after the corresponding value.
- bEfore value
- The number of instances is placed before the corresponding value.
- Count separator
- Sets the delimiter between a value and its number of encounters.
- count PREfix
- Sets the prefix that will be added before the number of encounters.
- count SUFfix
- Sets the suffix that will be added after the number of encounters.
- Units
- Configures units and how they display.
- unit Mode
- Sets the units for the column values.
- Best for All
- The best unit for all values.
- BEst for each value
- The best unit for each value.
- set Fixed unit
- Choose the unit manually.
- unit Format
- Sets how the units display.
- Title
- Places the unit symbol in the column title.
- Same cell
- Places the unit symbol in the same cell as the value.
- separate Column
- Places the unit symbol in a separate column.
- do Not show units
- Hides the units symbol.
- title Format
- Sets the format for the column title for the Title option.
- fOrmat string
- Sets the format string for column values.
- Role
- Sets the column role for the column.
- Regular
- Sets the regular role for the column.
- Number
- Sets the number role for the column. (So it will be used as the number source for the BMBALLON command).
- nAme
- Sets the name role for the column. (So it will be used as the name source for the BMBALLON command).
- Quantity
- Sets the quantity role for the column. (So it will be used as the quantity source for the BMBALLON command).
- table sEttings
- Configures the properties of a BOM table.
- footer Title
- Sets the title of the footer row.
- Filter
- Sets the table filter.
- Property set
- Specify the properties to add from.
- Mechanical only
- Only mechanical properties of components and instances will be available.
- all Except coordinates
- All properties of mechanical components and instances will be available, including properties of associated database entities, except coordinates.
- All
- All properties of mechanical components and instances will be available, including properties of associated database entities.
- Grouping mode
- Specifies the grouping mode for the current table.
- Auto
- Groups the parts with respect to their definitions and parameters.
- by COmponents and columns
- Groups the parts with respect to their definitions and properties used in the table.
- by Columns only
- Groups the parts with respect to their properties used in the table only. (So one row may correspond to completely different parts if their properties displayed in BOM are the same).
- Counting mode
- Specifies the counting mode for hierarchical BOM.
- by Document
- Sets the counting mode to count all instances.
- by parent Component
- Sets the counting mode to count instances in parent component.
- Max level
- Allows to specify the maximal level of parts in hierarchical BOM tables.
- Selection set
- Allows to specify a selection set linked to this BOM table.
- Entire model
- Sets entire model as the selection set.
- Subassembly
- Sets a selected subassembly as the selection set.
- Custom selection
- Sets a custom selection of top-level components as the selection set.
- drawing View
- Associates this BOM table with selected drawing views.
- layout viewPOrt
- Associates this BOM table with selected layout viewports.
- fixed coRner
- Changes the fixed corner of the table. The fixed corner will remain in
position during table changes.Note: Press the Tab key to cycle the corners of the table. The table position will change to place the fixed corner under the cursor, thus helping to align the table with other objects in the drawing.
- Top Left
- Sets top left corner of the table as fixed.
- Top Right
- Sets top right corner of the table as fixed.
- Bottom Left
- Sets bottom left corner of the table as fixed.
- Bottom Right
- Sets bottom right corner of the table as fixed.
- Back
- Returns to the previous prompt.
