BMBOM command
Inserts a Bill of Materials (BOM) table in the current drawing.
Icon:
Options within the command
名称(N)
Specifies the table name.
顶层
Creates a BOM of the top-level components only.
底层
Creates a BOM of the subcomponents.
分级
Creates a hierarchical BOM listing all (sub)components.
从模板加载
Creates a BOM from a template.
另存为模板
Saves the current BOM configuration as a template.
LAyout
Changes the current layout.
配置
Add additional columns to your BOM table.
描述(D)
Add a description column.
密度(E)
Add a density column.
体积(V)
Add a volume column.
质量
Add a mass column.
参数(S)
If multiple inserts of the same parametric component exist in the assembly, they will be grouped in different BOM rows depending on the values of the parameters.
物料(A)
Add a material column.
厚度(T)
Add a thickness column.
Note: If a component is a sheet metal part, this column shows the thickness of the part. Otherwise, it is empty.
更多
Displays more configuration options.
切换列
Adds or removes columns from the BOM.
add Formula field
Adds a formula field.
集排序
Sets the sorting mode for BOM.
自动的
Sets the automatic sorting for the table.
没有排序
Disables the sorting for the BOM.
自定义排序
Specifies the column for sorting.
切换排序列
Sets the sorting mode for columns.
column Properties
Configures columns.
名称(N)
Sets the name of the column.
可见性
Sets the visibility of the column.
ON
Sets the visibility of the column to on.
关闭(OFF)
Sets the visibility of the column to off.
宽度
Sets the column width.
自动
Sets the automatic width of the column.
前缀
Sets the prefix for numbers in the Number column.
后缀(S)
Sets the suffix for numbers in the Number column.
页脚类型
Sets the footer type.
Removes the column from the footer.
总数
Adds the total sum to the footer.
平均
Adds the average value to the footer.
MINimum
Adds the minimal value to the footer.
MAXimum
Adds the maximal value to the footer.
汇总函数
Sets the aggregate function.
Removes an aggregate function from the column.
总数
Shows the total sum of values in the group.
平均
Shows the average value of values in the group.
MINimum
Shows the lowest value in the group.
MAXimum
Shows the highest value in the group.
CONcatenate
Combines all values in the group using the provided delimiter.
CONCatenate with count
Combines all values in the group with their number using the provided delimiters, prefix and suffix.
设置(E)
Configures the aggregated column.
value Separator
Sets the delimiter between concatenated values.
count Position
Sets the position of the number of encounters for concatenated values.
后值
The number of instances is placed after the corresponding value.
bEfore value
The number of instances is placed before the corresponding value.
计数分隔符
Sets the delimiter between a value and its number of encounters.
count PREfix
Sets the prefix that will be added before the number of encounters.
count SUFfix
Sets the suffix that will be added after the number of encounters.
单位
Configures units and how they display.
unit Mode
Sets the units for the column values.
Best for All
The best unit for all values.
BEst for each value
The best unit for each value.
set Fixed unit
Choose the unit manually.
unit Format
Sets how the units display.
标题
Places the unit symbol in the column title.
同一单元
Places the unit symbol in the same cell as the value.
separate Column
Places the unit symbol in a separate column.
do Not show units
Hides the units symbol.
title Format
Sets the format for the column title for the Title option.
fOrmat string
Sets the format string for column values.
角色
Sets the column role for the column.
正常的
Sets the regular role for the column.
数字(N)
Sets the number role for the column. (So it will be used as the number source for the BMBALLON command).
nAme
Sets the name role for the column. (So it will be used as the name source for the BMBALLON command).
数量
Sets the quantity role for the column. (So it will be used as the quantity source for the BMBALLON command).
table sEttings
Configures the properties of a BOM table.
footer Title
Sets the title of the footer row.
筛选
Sets the table filter.
属性集
Specify the properties to add from.
仅机械
Only mechanical properties of components and instances will be available.
all Except coordinates
All properties of mechanical components and instances will be available, including properties of associated database entities, except coordinates.
全部
All properties of mechanical components and instances will be available, including properties of associated database entities.
分组模式
Specifies the grouping mode for the current table.
自动
Groups the parts with respect to their definitions and parameters.
by COmponents and columns
Groups the parts with respect to their definitions and properties used in the table.
by Columns only
Groups the parts with respect to their properties used in the table only. (So one row may correspond to completely different parts if their properties displayed in BOM are the same).
计数模式
Specifies the counting mode for hierarchical BOM.
by Document
Sets the counting mode to count all instances.
by parent Component
Sets the counting mode to count instances in parent component.
选择集
Specifies the selection method for the BOM.
整个模型
Creates a BOM for the entire model.
子装配
Creates a BOM for the selected subassembly.
自定义选择
Creates a BOM for the selected components.
drawing View
Specifies one or more drawing views.
layout viewPOrt
Specifies one or more layout viewports.
fixed coRner
Specifies the position of the insertion point of the table.
Returns to the previous prompt.
