BMCONNECT command
Connects two Piping standard parts by creation of 3D constraints between their connection entities.
Icon:
选项(O)
Select StdPart to connect
Select the part to connect. (1)
Select target StdPart
Select the part to connect to. (2)
The command automatically creates a set of 3D constraints to correctly connect the parts and maintain their relative position for any further modification.
