BMCONVERT command
Converts BIM Linear solids with circular profiles to Mechanical assemblies.
Method
Select entities to convert and choose the proper styles for pipes.
Options within the command
- Pipe
- Allows you to select a style for the pipe segment.
- Elbow
- Allows you to change the styles for the pipe elbows (45 deg and 90 deg).
- Reducer
- Allows you to change the styles for the pipe reducers (concentric and eccentric).
- Splitter
- Allows you to change the styles for the pipe tee and pipe cross.
Lists available styles
Note: Use ; to select multiple styles.
- Use current
- Uses the current style.
- SETtings
- Opens the Settings dialog box with the Conversion section expanded.
