BMEXPLODE command
Creates a block with an exploded representation of the current assembly.
Icon:
描述(D)
Creates a block with an exploded representation of the current assembly. This block can be inserted at any given location.
方式
It supports two levels of the exploded representation: top and bottom. Top-level means that the assembly will be exploded down to top level components; Bottom-level means that the assembly will be exploded down to bottom level components.
The steps to create an exploded representation are automatically completed and are displayed in the Mechanical Browser. You can add, delete and reorder the steps from the Mechanical Browser. Animate a single step of an explosion or the entire sequence.
选项(O)
- 表格依类型
- Groups identical parts on the same row and different parts on different rows.
- 线性(L)
- Automatically creates exploded representations of assemblies in a given direction, taking into account possible physical collisions between components.
- 自动的
- Automatically determines the directions for each part, taking into account possible physical collisions between components.
- 启用引线从动
- Enables the detection of parts that should move in a coherent manner. If enabled, parts that are inserted into other parts will follow the movement of the base parts they are inserted into.
- 使用当前投影作为间隙
- Enables the gap calculation with respect to the current camera orientation. It minimizes the probability that some parts will be hidden by other parts on a 2D view with the current camera orientation.
- 自动
- Enables automatic gap calculation.
- 手动(M)
- Selects the manual mode. This creates an exact copy of the assembly, ready to create a customized exploded view.
- 设置(S)
- Gives access to the command settings.
- 顶(T)
- If selected, the assembly will be exploded using only top-level components.
- 底(B)
- If selected, the assembly will be exploded down to bottom-level components.
- 设置名称
- Set the name for the exploded representation.
- 退回
- Returns to the previous prompt.
- 编辑(E)
- Opens the exploded representation for editing.
- 产生图形视图
- Generates drafting views from an exploded representation.
- 完成
- Concludes the command.
