BMEXPLODECONFIG command
Assigns preferable directions for entities during automatic generation of exploded views.
Automatically converts directions defined in WCS to local directions of selected entities during generation of exploded views.
Method
Select entities which will use the preferable direction for exploded view, then set the direction.
Options within the command
- Set
- Selects entities to set preferable direction for disassembly.
- Remove
- Selects entities to remove from preferable direction for disassembly.
- Select the direction
- Selects the direction for selected entities which will be follow on exploded views.
