BMHARDWARE command
Opens the Library panel.
BricsCAD Mechanical
Icon:
Opens the Library panel to display it in the current workspace. The Library panel appears at the same size and location as before it was closed or collapsed. Like any other dockable panels, the Library panel can be either floating, docked or stacked.
