BMHIDE command
Hides an inserted mechanical component.
Icon:
描述(D)
Hides a mechanical component inserted in the current drawing.
The command affects the visibility of the selected inserts only. Hidden inserts will still be considered by commands such as BMBOM, BMMASSPROP etc.
选项(O)
- 组件名称
- Type the component name of the component insert(s) you want to hide. All inserts of the specified component will be hidden.
- 插入名称
- Type the insert name of the component insert you want to hide.
