BMLINK command
Changes target 3D solids of component-based features.
Icon:
描述(D)
Changes the target 3D solids of component-based features by adding or removing target 3D solids.
Options within the command
- 更改目标3D实体
- Specifies a set of target solids. Component-based features will be removed and new ones will be created for selected solids.
- 附加(A)
- Adds new solids to set of target solids. Component-based features will be updated and new ones will be created for the selected solids.
- 清除(R)
- Removes the existing component-based features and their geometry (see the BmUnlink command).
- 选择所有受影响的3D实体
- This mode is similar to 'Change target 3d solids' but solids are chosen automatically.
