BMLOCALIZE command
Converts external components to local components.
Icon:
Converts external components to local components by selecting the components manually.
Note: Mechanical external references are supported as well as traditional mechanical components.
If multiple inserts of the same external component exist in the model, all inserts are converted to local components.
Options within the command
Entire model
Converts all external components in the model to local components.
