BMOPENCOPY command
Opens a copy of a component insert as a new drawing.
Icon:
Opens a copy of a selected external mechanical component in a new drawing.
If you open a copy of a parametric mechanical component, the current values of the various parameters are applied to the copy.
After saving it you may replace the original component with the newly created drawing using BMREPLACE command.
