BMRECOVER command
Recovers a broken mechanical structure.
Recovers a broken mechanical structure selected through the Select file dialog box. The command overwrites the original drawing.
Note: The command differs from the basic Audit and Recover
commands. It is recommended to use BMRECOVER to mend issues with a MCAD
drawing.
