BMSHOW command
Shows hidden mechanical components from the drawing.
Shows previously hidden mechanical components inserted in the current drawing.
Options within the command
show ALl
Shows all component inserts.
COmponent name
Type the component name of the component insert(s) you want to show. This affects all inserts of the specified component.
Insert name
Type the insert name of the component insert you want to show.
If you want to show a nested component insert (subcomponent insert), first type the insert name of the parent component insert, then the component insert name separated by a forward slash (/).
