BMTRAILINGLINES command
Creates all necessary trailing lines for selected parts.
Creates all necessary trailing lines by selecting entities.
Note: An exploded view needs to be selected before the command
can be run.
Options within the command
- use Origin points
- Switches the mode used to choose the reference point for parts to the origin (insertion point) of the component.
- use Center points
- Switches the mode used to choose the reference point for parts to the center point of the bounding box of the component.
- Entire model
- Selects the entire model and starts the processing.
