CENTERMARK command
Creates a center mark.
Icon:
Alias: CM
Creates a center mark associated with a selected circle, arc, or polyarc.
Methods to create a center mark
There is one method to begin creating a center mark:
- Select circle or arc
- Begin creating a center mark by selecting a circle, arc or polyarc. Depending on the current value of the CENTERMARKEXE system variable, the center mark is drawn with or without extension lines. Additional center settings further control the appearance of centermarks.
Options within the CENTERMARK command
After you begin creating a center mark, the following option may be available:
