CENTERREASSOCIATE command
Associates a centerline entity with two selected lines, or else a center mark with a circle or an arc.
Icon:
Selects the center mark or a centerline to associate with their specific entities.
If you select a center mark you have to specify a circle or an arc (circular entity) to associate with.
If you select a centerline you have to specify two lines to associate with.
