CHPROP command
Changes the properties of the selected entity.
Changes the properties of the selected entities, with fewer options than the CHANGE command. You can change the properties for one or multiple entities.
Note: This command is largely superseded by the properties
panel.
Options within the command
- Color
- Changes the color of the entity.
- COlorbook
- Select colorbook to append.
- LAyer
- Changes the layer to which the entities are assigned.
- LineType
- Changes the linetype. Linetype must be loaded into the drawing.
- linetype Scale
- Changes the linetype scale.
- Line Weight
- Changes the lineweight.
- Thickness
- Changes the thickness.
- TRansparency
- Changes the transparency.
- Material
- Applies a material.
- Annotative
- Sets the annotative property.
