CHSPACE command
Moves entities from paper space to model space and vice versa.
Note: This command can only be used in a Paper Space.
Method
There are two methods to use CHSPACE command:
- Moves entities from paper space to model space.
- Moves entities from model space to paper space.
Options within the command
Note: The following options are available only with multiple
viewports active
- Select TARGET viewport
- Select target viewport as reference.
- Select SOURCE viewport
- Select source viewport as reference.
