CHSPACE command
Moves entities from paper space to model space and vice versa.
Note: This command can only be used in a Paper Space.
Method
There are two methods to use CHSPACE command:
  • Moves entities from paper space to model space.
  • Moves entities from model space to paper space.
Options within the command
Note: The following options are available only with multiple viewports active
Select TARGET viewport
Select target viewport as reference.
Note: The scale factor is the inverse of custom scale of the selected target viewport. For example, if the custom scale = 1/2 (0.5), then the scale factor = 2.
Select SOURCE viewport
Select source viewport as reference.
Note: The scale factor equals the custom scale of the selected source viewport.
