CIRCLE command
Creates circle entities.
Icon:
Alias: C
Creates a circle from a combination of options including the center, radius, two points, three points or tangent to entities. You can also convert an arc to a circle.
Methods
There are 7 different methods to create circle entities:
Center-Radius
Center-Diameter
2 Point
3 Point
Tangent-Tangent-Radius
Turn Arc into circle
Multiple circles
Options within the CIRCLE command
Select center of circle
Specify a point (1)
Set Radius
Specify a point (2)
Set Diameter
Specify a point (3)
2P
Specify 2 diametrically opposite points (1 and 2) to define the circle.
3P
Specify 3 points to define the circle. Tangent entity snap allows defining a circle by picking 3 tangent points to other entities. The TanTanTan method is also available by AI_CIRCTAN command.
Define the circle by two tangent points (to other entities – 1 and 2) and its radius. When you specify a radius that is not possible with the selected tangents, you are prompted to specify the second tangent and the radius again.
Converts an arc entity into a circle by extending it to 360 degrees.
Multiple circles
Create multiple circles with the same size using one of the listed methods above. Press Enter to end the command.
