CIVIL3DIMPORT command
Creates BricsCAD civil entities from an Autodesk® Civil 3D drawing.
Opens the Import Civil 3D dialog box which allows you to import AutoCAD® Civil 3D entities from a selected .dwg file, or to convert them directly from the current drawing.
The following objects from AutoCAD® Civil 3D can be imported, which are in BricsCAD® also created as Civil entities:
  • Cogo points and point groups
  • TIN Surfaces
  • TIN Volume Surfaces
  • Grid Surfaces
  • Alignments (both Alignments by PI and Alignments by Elements are supported)
  • Profile Views
  • Profiles (Vertical Alignments)
