CIVIL3DIMPORT command
Creates BricsCAD civil entities from an Autodesk® Civil 3D drawing.
Opens the Import Civil 3D dialog box which allows you to import AutoCAD® Civil 3D entities from a selected .dwg file, or to convert them directly from the current drawing.
The following objects from AutoCAD® Civil
3D can be imported, which are in BricsCAD®
also created as Civil entities:
- Cogo points and point groups
- TIN Surfaces
- TIN Volume Surfaces
- Grid Surfaces
- Alignments (both Alignments by PI and Alignments by Elements are supported)
- Profile Views
- Profiles (Vertical Alignments)
