CIVILPOINT command
Creates Civil Points.
Icon:
Civil Points are defined in BricsCAD® as a Civil entities, which are represented by symbols and labels. In addition to XYZ coordinates, Civil Points can have a variety of attributes assigned, including point number, point name, raw (field) description and full (expanded) description.
Use the Properties panel to edit the properties of an individual point or a group of selected points.
For improved organization, Civil Points can be collected into point groups based on certain criteria determined by filters.
You can use the basic BricsCAD® commands to edit Civil Points in a drawing. For example, COPY, COPYCLIP, PASTE, MOVE, ROTATE...
You can use Civil Points as input objects for creating a TIN Surface, which is automatically updated when editing points.
Method
- Insert a single point by specifying its location in a drawing.
- Import multiple points from an ASCII point file.Note: In addition to the basic ASCII file, points can also be imported from a LandXML file using the LANDXMLIMPORT command.
Options within the command
- Specify point location
- Allows you to specify the location of a new individual point in a drawing.
- Import points from file
- Opens the Open LandXML file dialog box which allows you to import Civil
Points from an ASCII point file.
Currently, only XYZ coordinates are imported from an ASCII point file, without additional attributes that may be included in the input file. The input point file can have any extension, for example .xyz, .txt, .asc...
- Enter point description
- Allows you to specify a description for the Civil Point.
- Enter point elevation
- Allows you to specify an elevation for the Civil Point.
- Enter point file delimiter
- Allows you to specify a character that separates the point data
(attributes) in the specified ASCII point file.
Columns in the input file can be delimited by any character (delimiter), which is specified by the user when importing the file.
- set Style
- Allows you to specify a point symbol style when inserting a new
point.Note: More information on point styles and labels can be found in the Working with Civil points article.
- Lists the names of the available point symbol styles in the Command line.
