CIVILPOINTGROUPEDIT command
Edits Civil Point groups.
Icon:
This command allows you to change the name of the selected point group or delete it.
Options within the command
Enter point group to edit
Allows you to enter the point group name to edit.
? to list point groups
Lists existing point groups in the drawing on the Command line.
? to list points
Lists all points that are included in the selected point group on the Command line.
Remove
Allows you to remove the selected point group.
rEname
Allows you to rename the selected point group.
