CONE command
Creates a 3D Solid in the shape of a cone.
Note: In BricsCAD Lite, which doesn’t support 3D solids, the CONE command launches the AI_CONE command.
Icon:
描述(D)
Creates a 3D solid in the shape of a circular or elliptical cone. Choose from a combination of options including center, radius, diameter, 3 point, 2 point, tangents, axis endpoints, and height.
Methods to create a cone
This command has 5 methods to begin creating a cone:
- 指定中心点
- 3 Point
- 2 Point
- 相切-相切-半径
- Elliptical
- 指定中心点
- Begin creating a circular cone by specifying the center of the base then:
- Radius of base of cone
- Specify the radius of the base of the cone.
- 指定高度
- Specify the height of the cone.
- 3 Point
- Begin creating a circular cone by specifying the first of three points on the circumference of its base then:
- 第二点
- Specify the second point on the circumference.
- 指定第三点
- Specify the third point on the circumference.
- 指定高度
- 2 Point
- Begin creating a circular cone by specifying the first of two points on the circumference of its base then:
- 指定直径的第二端点
- Specify the second point on the diameter. The two points define the diameter of the base.
- 指定高度
- Tangent Tangent Radius
- Begin creating a circular cone by selecting a tangent point on the first entity then:
- 指定对象上的点作为第二个切点
- Select a tangent point on the second entity.
- 指定圆形选取半径
- Specify a valid radius for the base. If you specify a radius that is not possible with the selected tangents, you are prompted to specify the tangents and radius again.
- 指定高度
- Elliptical
- Begin creating an elliptical cone by specifying the first end of the ellipse axis then:
- 指定椭圆轴第二端点
- Specify the second end of the ellipse axis.
- 指定另一端的椭圆轴
- Specify the radius of the other ellipse axis.
- 指定高度
Options within the CONE command
After you begin creating a cone, the following options may be available:
- 2点
- Specify the height of the cone as the distance between any two points.
- 轴端点
- Specify the axis endpoint to define the height and orientation of the cone in 3D space. The center of the base is used as the other axis endpoint.
- 顶部半径
- Specify a radius for the top of the cone. Any radius larger than zero (0) creates a cone with a flat top.
- 直径(D)
- Specify the diameter of the cone’s base.
