Note: In BricsCAD Lite, which doesn’t support 3D solids, the CONE command launches the AI_CONE command.
Icon:
Creates a 3D solid in the shape of a circular or elliptical cone. Choose from a combination of options including center, radius, diameter, 3 point, 2 point, tangents, axis endpoints, and height.
Center
Diameter
Radius
Height
Methods to create a cone
This command has 5 methods to begin creating a cone:
Center point
3 Point
2 Point
Tangent tangent radius
Elliptical
Center point
Begin creating a circular cone by specifying the center of the base then:
Begin creating a circular cone by selecting a tangent point on the first entity then:
Specify point on object for second tangent
Select a tangent point on the second entity.
Radius of circle
Specify a valid radius for the base. If you specify a radius that is not possible with the selected tangents, you are prompted to specify the tangents and radius again.
