CONVERTPSTYLES command
Converts the current drawing from Color Dependent (CTB) to Named (STB) plot style mode and vice versa.
Note: A drawing can use either CTB or STB plot styles, but not both.
Converts the drawing’s plot style tables before converting the drawing, using the CONVERTCTB command.
