CONVTOMESH command
Converts entities to mesh entities.
Converts valid 2D and 3D entities to Mesh entities. Valid entities include:
- 3D Solid
- Surface
- Polygon Mesh
- Region
- Closed Polyline
Method to convert to mesh
There is one method to convert entities to Mesh entities:
- Select entities
- Select Entities
- Begin converting an entity to a Mesh entity by selecting a valid entity then:
- Select entities
- Select another valid entity or press Enter to complete the command.
