CONVTOMESH command
Converts entities to mesh entities.
Converts valid 2D and 3D entities to Mesh entities. Valid entities include:
  • 3D Solid
  • Surface
  • Polygon Mesh
  • Region
  • Closed Polyline
Method to convert to mesh
There is one method to convert entities to Mesh entities:
  • Select entities
Select Entities
Begin converting an entity to a Mesh entity by selecting a valid entity then:
Select entities
Select another valid entity or press Enter to complete the command.
Note: The BIM data and GUID are maintained after converting.
