CONVTOSURFACE command
Converts entities to Surface entities.
Converts valid 2D and 3D entities to Surface entities. Valid entities include:
  • 2D Solid
  • 3D Solid
  • Region
  • Open Polyline with non-zero thickness and zero width
  • Line with non-zero thickness
  • Arc with non-zero thickness
  • Circle with non-zero thickness
  • Mesh
  • Planar 2D Face
Method to convert to surface
There is one method to convert entities to Surface entities:
  • Select entities
Select Entities
Begin converting an entity to a Surface entity by selecting a valid entity then:
Select entities
Select another valid entity or press Enter to complete the command.
