CORRIDORTEMPLATEELEMENT command
Creates a corridor template element from polylines with a specified base point and orientation (left, right, none).
![BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V23/en_US/command-reference-pro-mechanical-bim.png)
Icon:
The geometry of the corridor template element is created on the basis of the specified polylines, which can later be edited with the command CORRIDORTEMPLATEELEMENTEDIT.
Input polylines can contain a large number of segments. An individual segment can be drawn as a line or arc. The ARCTESSELLATIONTEMPLATEELEMENT system variable controls the Mid-Ordinate Distance parameter which approximates arc segments.
Method
Select polylines to create a corridor template element and specify the base point.
Options
- None
- No orientation.
- Right
- Right orientation.
- Left
- Left orientation.
