DDEMODES command
Sets default values for creating entities.
Displays the Entity Creation section of the Settings dialog box.
Note: This command is superseded by the Settings command.
Method
Displays Settings dialog box at the Entity Creation section:
- Entity color
- Entity linetype scale
- Entity linetype
- Entity lineweight
- Transparency for new objects
- Current layer
- Current table style
- Linetype scale
Options
- Entity Color
- Specifies the default color of new entities; initial value is ByLayer, which means that entity colors are governed by layer properties.
- Entity Linetype Scale
- Specifies the default scale factor for linetypes; initial value is 1.0000.
- Entity Linetype
- Specifies the default linetype for new entities; initial value is ByLayer, which means that entity linetypes are governed by layer properties.
- Entity Lineweight
- Specifies the default linetype for new entities; initial value is ByLayer, which means that entity lineweights are governed by layer properties.
- Current Layer
- Specifies the default layer for new entities; initial value is layer 0.
- Current Table Style
- Specifies the initial value of the table style name for new tables.
- Linetype Scale
- Specifies the global linetype scale factor; this factor affects entity linetype scale factors.
