DELAY command
Delays execution of commands.
This command is used to delay the execution of the next command.
Note: Meant to use with scripts.
Options within the command
Milliseconds to delay
Specifies the amount of time BricsCAD waits before continuing to the next command in the script.
Note: Enter a number between 0 and 2,147,483,627(approximately 24 days).
