DIMALIGNED command
Creates an aligned dimension.
Icon:
Alias: DAL, DIMALI
描述(D)
Creates a dimension that aligns with the origin points of the extension lines. The dimension is based on the current dimension style. Options allow you to specify the angle and contents of the dimension text.
Methods to create an aligned dimension
This command has 2 methods to begin creating an aligned dimension:
- 指定第一条延伸线原点
- 选择实体
- 指定第一条延伸线原点
- Begin creating an aligned dimension by specifying a point for the first extension line then:
- 指定第二条延伸线原点
- Specify a point for the second extension line.
- 指定标注线位置
- Specify the location of the dimension line. The dimension is placed at the same distance from each of the extension line origins.
- 选择实体
- Begin creating an aligned dimension by pressing Enter then:
- Select entity to dimension
- Select a line, polyline segment, arc, or circle to dimension. When selecting a line, the endpoints of the line are used for the extension origins. When selecting an arc, the endpoints of the arc are used for the extension origins. When selecting a circle, the selection point on the circle is used for the first extension origin and the opposite point on the diameter of the circle is used for the second extension origin.
- 指定标注线位置
Options within the DIMALIGNED command
After you begin creating an aligned dimension, the following options may be available:
- 角度
- Specify the angle of the dimension text. A value of 0 aligns the dimension text with the dimension line. Any other value rotates the dimension text relative to the x-axis of the current UCS.
- 文字(T)
- Enter text to override the default dimension text which includes the measured length of the dimension. You can use two angle brackets <> to display the measured length of the dimension in addition to other text.
